It is currently Tue Aug 12, 2025 8:44 am
PostPosted: Thu Jan 14, 2016 2:26 am
We tried ebony bindings for the first tine and they blew to bits in the bender? Anyone got tips?
PostPosted: Thu Jan 14, 2016 3:15 am
Any sign of extreme runout/diagonal grain?
PostPosted: Thu Jan 14, 2016 4:04 am
A bit but not moreso than other woods that have played nice.
PostPosted: Thu Jan 14, 2016 5:38 am
From what I've heard, Ebony's not other woods...
PostPosted: Thu Jan 14, 2016 7:28 am
State: Tennessee
Hmmmm, I've bound two guitars with ebony. Bent nine pieces and one broke, the one that had noticeable runout at the break
PostPosted: Thu Jan 14, 2016 9:20 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I bend Ebony at 350-375 degrees and have had one small crack that was repairable.
It will probably be alright.
PostPosted: Thu Jan 14, 2016 2:25 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Ebony seems to vary wildly on bendablility. I have had pieces that just won't bend. Superset does help. If you dry it out too much trying to get it too hot it often pops apart. I would Supersoft your bindings and wrap them in foil for a day before bending.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Thu Jan 14, 2016 2:56 pm
City: Tyler
Bend hot. I've broken plenty of ebony bindings.
PostPosted: Thu Jan 14, 2016 7:50 pm
Last Name: Sollod
I guess i got lucky bending ebony bings. Successfully Bent them in my bender along with a black limba side using supersoft. I thinned them to near 0.060"...
www.swiftcreekguitars.com
PostPosted: Thu Jan 14, 2016 8:44 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I know you want to bend them in the bender, but if that isn't cooperating, a hot pipe could be the way to go. I've only bound one guitar with ebony, but the pieces bent pretty easily with the hot pipe set at 6 1/2 out of 7 on the temp control knob and with liberal spritzing with water. All four pieces were taped together and bent at the same time. The binding was 1/4" x 0.080".
PostPosted: Fri Jan 15, 2016 12:23 pm
First name: Danny
Last Name: Vincent
Best tip I could give you is to use Blackwood. Butter.
PostPosted: Fri Jan 15, 2016 2:00 pm
First name: Brad
Last Name: Combs
I've bent 3 sets of BI3IE from LMI: http://www.lmii.com/products/mostly-woo ... od-binding
I bent at 150c using what is becoming my typical approach for the side bending jig:
1) Spray with water, rather liberally, and wrap in aluminum foil.
2) Place in the bender sandwich and press the waist down just until the registration bar is seated into the slot in the bending form.
3) Turn on the silicone blanket.
4) At 100c start to crank the waist down. I do half a turn on the veneer press every 20 secs.
5) Once the waist is down attach the upper and lower bout blocks.
6) I start with the upper bout, don't know if it matters. Every 20 seconds move the bout block about an inch further down until fully bent.
7) Do the other bout the same way.
This was in one of the books I have and it has worked well for any bend I've done with the exception of Zebrawood which needed to be much thinner (0.65) compared to any binding or other sides I've bent. The thinner Zebrawood bent nicely too though, but I used less water to prevent cupping.
I'm new to this, so keep that in mind. Just my limited experience on a few bends. :)
Hope that helps.
Brad
Users browsing this forum: Bing [Bot], rbuddy and 52 guests
